Strange behavior
Strange behavior
I can't remember how this happened.
There were Track1@DJ1, Track2@DJ2, Track3@DJ3
I hit a key combination and deleted Track1.
This track deleted from playlist, but instead of loading Track4 to DJ1 it loaded again Track3 to DJ1 but without showing it to playlist.
ss2014-10-03 (1).png (34.26 KiB) Viewed 5341 times
I then hit F9 and started playing DJ3 that had Track3 again, but again without this existing in playlist.
ss2014-10-03 (2).png (47.35 KiB) Viewed 5341 times
And one more question: What is Ctrl+Shift+F7 is doing ? There is also a Shift-Ctrl+F7 showing under big eject button. What is the difference ?
ss2014-10-03 (3).png (10.31 KiB) Viewed 5341 times
Re: Strange behavior
I think that it was Ctrl+Shift+F5
Follow is unchecked and Preserve is checked.
I am wondering about the opposite: How can someone reproduce this case ?
One simple way is the following:
- load a couple of tracks to a new playlist
- click on AutoPlay (so that all players are loaded and A is playing)
- select the first track (the one playing in A)
- hit Shift+Del (this removed the selected tracks from the playlist, but as A is playing it won't automatically unload)
Without knowing what key combos you exactly hit it is hard to say...
It also depends on your 'Follow' and 'Preserve' setting (see the main ribbon)...
The Ctrl+Shift+F7 combo in the 'Direct Pause' tooltip is incorrect and will be removed in the next version, but that's just a tool tip display thing.
Shift+Ctrl+F7 is actually used with the 'Direct Eject C' button.
