v3.0.14.17 - stable
v3.0.14.17 - stable
Version 3.0.14.17 is out!
What's New?
  • Toggle AutoPlay behavior changed
  • new Level Meter 0 dB FS scale
  • Serial IO config bug-fix
  • Duration EmbeddedScriptContainer now use TryEnsureExactLength
  • Script-Line mode 'Execute' optionally use TryEnsureExactLength
  • Other smaller bug-fixes
  • stable
So far toggling AutoPlay did not consider any currently open/playing OverlayPlayer, but started AutoPlay immediately for the current playlist.
This has now change! Toggling AutoPlay while the OverlayPlayer is open/playing it won't start any playback immediately, as the Overlay Player would now resume it once finished.
As already explained here: viewtopic.php?f=8&t=1183&start=10#p5123
I now implemented a (new) peak level meter using a 0 dB FS scale plus an overload indicator (orange = near overload between -0.2dB and 0.0dB and red = overload above 0.0dB).
In addition does the 'Station Information' window now contain a new 'Show LevelMeter' option - so you can now either display the station logo, a mixer channel FFT visual or a mixer channel level meter.
When using the script-line mode 'Execute' you might now specify an optional Duration. If specified, the related script will execute using the TryEnsureExactLength option and return a list of tracks matching (almost) that given duration. Note, that the count parameter is still used and specifies the minimum number of elements to return!
Any dynamic embedded script container using a given duration now also always uses the TryEnsureExactLength option.
Note: v.17 was needed as a rebuild, as the original .16 contained a bug declaring a folder bowser dialog which might lead to an unhandled exception.
