Schedule a playlist
amaurydixx
Schedule a playlist
Post by amaurydixx »
Sometimes, I manually create playlists without script.
How can I schedule these playlist?
Thank you.
Re: Schedule a playlist
You can only schedule a Script. BUT to effectively schedule a playlist you can create a very simple script with at least one script line using the 'LoadPlaylist' mode.
In addition you can try the 'Playlist Template Wizard' which can be found underneath the 'New ' main ribbon item. This one also schedules a playlist and creates a related script and scheduler entry automatically...
