Event only 2 times in 4 hours
amaurydixx
Post by amaurydixx »
I have got a script named "Playlist" who play A jingle and a track.
I called this script to generate a playlist of 4 hours.
I would like to put in this playlist a container which contains :
- the top of the hour
- a new (created in the news & ad tool)
I have to put this container in the begining of the playlist and after 1 hour (example: if the playlist is played at 2 o'clock, i have to put the container at 2 and 3 o'clock)
How can i do?
Re: Event only 2 times in 4 hours
Within the script itself you can not put any time related information.
As such you must either use a FixTimeElement (FTEs; which can be defined by clicking on the FixTimeElement button from within the Script Editor) or directly schedule the News, Adverts and ToTH with e.g. the Overlay Scheduler.
When using FTEs you can use the 'News' and 'Advert' mode to define a News resp. an advert slot.
Also click on the '?' icon at the top right of each dialog window to get detailed help about all its options...
For more info, please also see these topics:
viewtopic.php?f=9&t=904
viewtopic.php?f=9&t=31
