v3.0.14.15 - stable
v3.0.14.15 - stable
Version 3.0.14.15 is out!
What's New?
  • Reload-Script bug-fix (in case system time is backdated in parallel)
  • Overlay Waiting-Countdown display optimized
  • New mixer channel related OnSilence/OnNoise events
  • Better folder select dialog
  • Prevent the system from entering sleep mode
  • New Scheduler-Playlist did not start bug-fix
  • Playlist dynamic embedded container bug-fix
  • Initial streaming-server startup bug-fix
  • Overlay combine parallel overlay bug-fix
  • Other smaller bug-fixes
  • stable
The countdown now estimates the effective start time of the overlay and displays that from the beginning (i.e. in case of AllowEarlyStart or a Soft start type).
You can now define control-command(s) for 2 new mixer channel related events: OnSilence and OnNoise.
To define/use them make sure you checked the ‘Enable Silence Detection’ option for the respective mixer channel (in its configuration dialog).
To use the events, go to the mixer control-command events, i.e. make a right-click onto the mixer-channel name and then select ‘Edit Control Command Events…’
Internal system calls now notify the OS about the need to stay awake. In case of power management enabled PCs this means, that the PC should not go into sleep mode in a regular way. Still these calls can not prevent the OS from entering sleep mode at all (e.g. if you or another system manually forces the sleep mode, this is still possible).
Note: In the next 2 weeks I will be a bit less available ;-)
XTended
Re: v3.0.14.15 - stable
Post by XTended »
Thanks for the new update!
It works great!
