Toggle auto play on and of
friso
Post by friso »
Bernd
I use a EXEC_SEND_TCP command to start and stop a stream, now i als want to stop and start the autoplay .
I have tested wit PLS_AUTOPLAY_TOGGLE, but i have to some playlist file behind it. But the name is always different.
What is the best way to start and stop the autoplay thrue that command
Thanx
Friso
Re: Toggle auto play on and of
Use the PLS_CURRENT_* commands to work with the current playlist. e.g. PLS_CURRENT_AUTOPLAY_TOGGLE.
The PLS_* (without CURRENT_) are used to work with playlists referenced by their name.
friso
Post by friso »
Bernd
Tested it with this line, but it didn't work. Switching on and of streamin works ok
192.168.1.129:8052|AUTHORIZATION 371222915${CRLF}${CRLF}STREAMING_SERVER_START Shoutcast V2 server Friso${CRLF}${CRLF}PLS_CURRENT_AUTOPLAY_ON${CRLF}${CRLF}
Please show the full command...Are you sending it from a different PF instance?
If yes, did you enable the TCP/IP Remoteing server on the receiving PF instance?
Make the call more simple and execute it from the command-line builder - then you will also see a possible result/error code.
E.g. use this command:
EXEC_SEND_TCP 192.168.1.129:8052|AUTHORIZATION 371222915${CRLF}${CRLF}SHOW_ALERT_WINDOW ONLINE|You are now online!${CRLF}${CRLF}
If that works, change it to:
EXEC_SEND_TCP 192.168.1.129:8052|AUTHORIZATION 371222915${CRLF}${CRLF}PLS_CURRENT_AUTOPLAY_ON ${CRLF}${CRLF}
(note the extra space after the parameter-less command!)
And if that works, just add more commands... etc.
friso
Post by friso »
Bernd
Solved the problem. It is not possible to execute more than one command.
I created another one, and all worked fine
Thanx
Friso
It is possible!
Try using a single ${CRLF} to separate the commands and end with a double ${CRLF}${CRLF} to terminate the sequence.
friso
Post by friso »
Bernd
Ok i will try that ;)
