Disable Overlay
Farbo
Disable Overlay
Post by Farbo »
When manually clicking on "Disable Overlay" nothing happens, overlay is not marked as played or something like that. How could I know it is working and overlay will not be played?
Peter
Re: Disable Overlay
Which "Disable Overlay" button do you mean?
Not sure what exactly you mean. Please explain your issues with a little more details, as it is hard to guess...
Farbo
Re: Disable Overlay
Post by Farbo »
I mean if I look at upcoming overlay in ribbon bar and with right click I want to disable some concrete overlay. For example I use overlay for hour signal but sometimes unfortunately happens that I am talking right before end of hour and I do not need this horu signal to be played-out.
Peter
Re: Disable Overlay
Yes, by clicking on the 'Disable Overlay' menu item in the context menu of the Upcomming Overlays you can manually disable that overlay (a red cross is displayed when disabled!).
However, such overlays need to have the following Options set:
- AllowModeratorChanges
- AllowCancel
Else you are not allowed to change that.
Farbo
Re: Disable Overlay
Post by Farbo »
OK, I will check later at home. I think the problem is I did not define AllowModeratorChanges and AllowCancel. Therefore nothing happens when I manually disabled overlay.
Peter
