New Find Track Fields Causing An Error
Added the last played field to the Track Find window. Tried to sort that date field. Clicked it a few times - but no sort was performed. Then the following error popped up:
7/11/2014 12:18:01 AM [v3.0.14.3]:********** Error/Exception Information **********
Error Message: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Error Type: System.ArgumentOutOfRangeException
Error Source: mscorlib.System.Object get_Item(Int32)
at System.Collections.ArrayList.get_Item(Int32 index)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.UpdateRowCellFloatLines(RowInfo ri, Boolean shouldHideLeftVerticalLine)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowCellsInfo(RowInfo ri, ArrayList viewInfoList)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowInfo(RowInfo ri, ArrayList viewInfoList)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowGroupInfo(TreeListNodes nodes, CalcRowGroupInfoArgs rowArgs)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.BriefCalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcViewInfo()
at DevExpress.XtraTreeList.TreeList.UpdateLayout()
at DevExpress.XtraTreeList.TreeList.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at DevExpress.XtraEditors.Container.EditorContainer.WndProc(Message& m)
at DevExpress.XtraTreeList.TreeList.WndProc(Message& m)
********** End **********
And the error log:
7/11/2014 12:17:58 AM [v3.0.14.3]:********** Error/Exception Information **********
at ProppFrexx.z.a(Exception A_0, Boolean A_1)
at ProppFrexx.dh.a(Exception A_0)
at ProppFrexx.dh.b(Exception A_0)
at ProppFrexx.dh.a(Object A_0, ThreadExceptionEventArgs A_1)
at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
at System.Windows.Forms.Application.Run(Form mainForm)
at ProppFrexx.d3.a(String[] A_0)
Not sure if this is helpful at all. I want to mention that ProppFrexx continued to play & stream uninterrupted (+++).
The find track window also got a weird sprite over it:
And the error log:
- find_track.jpg (106.32 KiB) Viewed 10923 times
Re: New Find Track Fields Causing An Error
That looks like a bug in the UI lib I am using.
I need to take a closer look and file that to the UI lib vendor.
Should be fixed with v3.0.14.4 !
Just upgraded to the latest version and this bug seems to have re-surfaced when I tried to sort the Find Track window.
And threw the following exception - thankfully ProppFrexx kept working
2/6/2015 8:48:06 PM [v3.0.14.38]:********** Error/Exception Information **********
at ProppFrexx.x.a(Exception A_0, Boolean A_1)
at ProppFrexx.dc.a(Exception A_0)
at ProppFrexx.dc.b(Exception A_0)
at ProppFrexx.dc.a(Object A_0, ThreadExceptionEventArgs A_1)
at ProppFrexx.d0.a(String[] A_0)
I just made a quick test here and I couldn't reproduce the issue/bug!
Please try to delete the "ProppFrexx ONAIR.Find.layout" file in your ProppFrexx AppUserData folder and try again...
If that doesn't help, please try to install the new v3.0.14.39 beta version, which is available in the "Check for Beta Versions..." menu item underneath the help menu at the very top right (blue question mark icon).
Thanks Bernd - deleting the layout file fixed the problem. Sort function works fine too.
