Serious problems with v .28
Bernd
I 've updated to .28 version but I have some serious problems.
It chooses random songs from my library ignoring my filters. It was working ok with previous version.
Also in find dialog the search takes too much time to give a result. More than 2 minutes. It was instant in previous version.
BUT the biggest problem is that it finds irrelevant songs.
I have screenshots that I'll attach tomorrow morning.
Re: Serious problems with v .28
That sounds very strange as the only change to the v.28 was the fix of the race condition in the overlay player. Which was just 3 lines of code. Nothing else was changed.
So it is strange why those totally unrelated function shouldn't work anymore?!
Have you grid to reboot your machine...
Look the playlist:
http://prntscr.com/3umrz1
Look my only one scriptline :
http://prntscr.com/3umso9
Look the tag of the file:
http://prntscr.com/3umssy
Look the result of the search:
http://prntscr.com/3umt8z
I noticed today that the search is faster and give correct results.
May the problem was that the MLS was loading and scanning that time ?
I think that after MLS scanned all my files this problem did not occur anymore.
Also today at 08:30 after the Time Announce overlay it stopped playing the playlist.
I had to click F9 to start again.
This is also HUGE PROBLEM because there was silence on air :(
Then you might go back to v.27.
With every update a backup (Previous version) folder is created, which you can simply copy back to your installation folder.
Bernd I know I can go back to v.27.
My question is : Do you confirm the bug?
Look at my debug file :
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' LoadScript 1 Script-Tracks found.
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' LoadScript finished 1 Total-Tracks (00:00:02.3250000 Playtime).
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' finish loading.
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' starting (1 Tracks).
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' PrepareOverlayStream (1 Tracks, Duration=00:00:02.3250000, LengthNext=00:00:02.3250000).
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' prepared.
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' DoPlayOverlay started.
20/06/2014 08:28:31: Parallel Overlay '_0830_34@2014-06-20T08:30:02' starts processing.
20/06/2014 08:28:31: Overlay '_0830_34@2014-06-20T08:30:02' starting LoadAdvertSlot.
20/06/2014 08:28:31: Overlay 'Time is (half past)@2014-06-20T08:30:00' ProgressChanged State=1.
20/06/2014 08:28:31: Overlay '_0830_34@2014-06-20T08:30:02' LoadAdvertSlot 0 Advert-Tracks (2 Total) found.
20/06/2014 08:28:31: Overlay '_0830_34@2014-06-20T08:30:02' LoadAdvertSlot finished 0 Total-Tracks (00:00:00 Playtime).
20/06/2014 08:28:32: OverlayScheduler: Overlay:_0830_34, Command:Advertising (_0830_34), Start:20/06/2014 08:30:02 processed
20/06/2014 08:28:32: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' PrepareOverlayStream (1 Tracks, Duration=00:00:02.3250000, LengthNext=00:00:02.3250000).
20/06/2014 08:29:09: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' stopping playlists (SuspendOthers=True, PauseOnSuspend=False).
20/06/2014 08:29:09: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' Start Playback (ManualStartType=False, ManualPlayout=False).
20/06/2014 08:29:09: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' ProgressChanged State=6.
20/06/2014 08:29:09: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' ProgressChanged State=10.
20/06/2014 08:29:09: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' Automatic-Playback (Entry=Η ώρα είναι 08-30).
20/06/2014 08:29:11: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' Playback-End (Pos=2,2406875, Remaining=0,0843124999999998).
20/06/2014 08:29:11: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' Playback finished.
20/06/2014 08:29:11: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' resuming playlist (WasAutoPlay=True, NeverAutoPlay=False, MODStream=None, ManualOperation=False).
20/06/2014 08:29:11: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' DoPlayOverlay finished (CanResume=True, CurrentPlaylistWasAutoPlay=True).
20/06/2014 08:29:12: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' ProgressChanged State=11.
20/06/2014 08:29:12: DJPlayerReport: Player=A, Event=TrackStop: Τσαλιγοπούλου Ελένη - Θαλασσογραφία
20/06/2014 08:29:12: DJPlayerReport: Player=A, Event=TrackCueOut: Τσαλιγοπούλου Ελένη - Θαλασσογραφία
20/06/2014 08:29:12: Overlay 'Time is (half past)+_0830_34@2014-06-20T08:30:00' RunWorkerCompleted (CheckResumed=False).
20/06/2014 08:29:12: Overlay Player closed.
20/06/2014 08:29:13: DJPlayerReport: Player=A, Event=TrackLoad: Καπαρού Αργυρώ - Γύφτισσα μέρα
20/06/2014 08:29:13: DJPlayerReport: Player=A, Event=TrackPause: Καπαρού Αργυρώ - Γύφτισσα μέρα
20/06/2014 08:30:23: PLS-PlayNext.
20/06/2014 08:30:23: DJPlayerReport: Player=B, Event=TrackPlay: Μολφέσης Αλέξανδρος - Σαν
20/06/2014 08:30:23: UpdateEntryStatistics 'Μολφέσης Αλέξανδρος - Σαν' PlayStart=2014-06-20T08:30:23
20/06/2014 08:32:59: PLS-DoPlayNextTrack: B.
20/06/2014 08:32:59: DJPlayerReport: Player=C, Event=TrackPlay: Μητροπάνος Δημήτρης - Το στοίχημα (Το τραγούδι της Ευτυχίας)
20/06/2014 08:32:59: UpdateEntryStatistics 'Μητροπάνος Δημήτρης - Το στοίχημα (Το τραγούδι της Ευτυχίας)' PlayStart=2014-06-20T08:32:59
20/06/2014 08:32:59: DJPlayerReport: Player=B, Event=TrackStop: Μολφέσης Αλέξανδρος - Σαν
20/06/2014 08:32:59: DJPlayerReport: Player=B, Event=TrackCueOut: Μολφέσης Αλέξανδρος - Σαν
Notice that at 20/06/2014 08:29:11 the overlay playback finished
but after a minute of silence I started (manually by F9) playback at 20/06/2014 08:30:23
Also I think that this post and the last pm I 've sent you, refer to the same problem. So probably it is not fixed and might happen again even in v.27
Please take a look.
I am trying v.29 now.
Just to let you know that the find bug still exist:
When I first run MLS and PF, while MLS is scanning folders, find dialog results in wrong files. If scan finishes result is ok.
This is what I am doing right now ;-)
Please try the new v3.0.13.29.
Note, that the rescanning was optimized in v3.0.13.30, so what you experienced should now not happen again!
The overlay playback issue in case the 'Allow Start Early' option was set should now also be fixed.
