How to remove non excisting scripts?
XTended
Question: How to remove non excisting scripts, already removed earlier this week?
- How-to-remove-old-scripts.jpg (40.66 KiB) Viewed 5227 times
Re: How to remove non excisting scripts?
Have those scripts be still currently be running?
With which version did you test that?
They should be removed with the next Reload. Click on the reload button in the general settings.
Note that this is only the case for scripts automatically load via the Auto Lib Path.
Manually managed scripts can directly be Removed.
XTended
Already did a reload in general settings but the old scripts are not gone in the script libraries.
We use another script directory "D:\_ProppFrexx\_Scripts" instead of the normal directory "C:\Users\ProppFrexx\AppData\Roaming\radio42\ProppFrexx ONAIR\3.0\scripts", could that be the problem?
XTended
I deleted all scripts and created new ones, did a reload and now its good....
Not the normal way, but it worked.
