v3.0.13.19 - stable
v3.0.13.19 - stable
Version 3.0.13.19 is out!
What's New?
  • Fault tolerant playlist reading
  • Better timeout handling for MLS
  • HighDPI display (DJPlayer) bug-fix
  • Manual Operations bug-fix
  • Some ribbon layout optimizations
  • Other smaller bug-fixes
  • stable
dokos
Re: v3.0.13.19 - stable
Post by dokos »
you can do a software update so that I could add a new cartwall 3, 4 and 5 in order to put rename own.
it would be more interesting and quickly switch between audio banks.
thank you,
Marian
dokos
Post by dokos »
Thanks Bernd,
Next time I will be better to read.
Still want to ask?
When the ad block length more than 3 minutes, sometimes it does not start autoplay.
The advert slot length or your overlay duration (not sure what exactly you mean) as nothing to do how it starts.
That only depends on the start type of the overlay.
What 'Start Type' have you set with the respective overlay?
Each Cartwall window has 4 shortcut buttons (when not used they are named '<Empty>', see the toolbar row).
You can assign any given cartwall lib to one of these shortcuts.
To assign a lib to a shortcut:
a) load a cartwall lib (from the toolbar combo box)
b) press and hold the CTRL key while clicking on a shortcut button
