Streaming shoutcast source drop outs
AladnaFm
Post by AladnaFm »
We are having set up a shoutcast stream in Proppfrexx with mp3 encoder 128kbps.
Streaming to a stream host.
The stream is making connection en is established, but it regularly keeps dropping the connection and reconnects after the 5 seconds I have set up.
<04/18/14@18:27:56> [source] source dropped connection. disconnecting.
<04/18/14@18:27:57> [main] connecting to yp.shoutcast.com to remove myself [no source]
<04/18/14@18:27:57> [yp_rem] yp.shoutcast.com removed me!
What am I doing wrong of what is going wrong?
Jesper, Aladna Fm
Re: Streaming shoutcast source drop outs
Have you checked your network or the network of your streaming provider?
Also what SHOUTcast server version is it?
I would assume, that this is a pure network issue...
AladnaFm
Post by AladnaFm »
Problem solved!! It was indeed a network issue, unstable internet connection.
