Red search results ?
andrerotgans
Post by andrerotgans »
I'll probably can find it somewhere in the 'what's new' release notes, but can't seem to find it on short notice : what's the difference between normal and red entries in the search result window ?
Re: Red search results ?
A 'red' entry in the Find window indicates, that this track was found in the global song history.
You can define this behavior in the 'Global History Options' (general settings, section 'Scripts/Scheduler', click on the 'More Global History Options...' button).
There you'll find the following option:
Check in Find Results: (Check History in Find Results):
Defines if the result entries of any search and find operation should be checked against the global song history.
If enabled any matching find result entries will be colorized.
Never: The find result entries are not checked against the global song history.
Trackname: The track name of the result entries will be checked against the global song history (no extended check is performed).
Full: Each result entry will be fully checked against the global song history. Caution: This setting might significantly slow down your search operation!
andrerotgans
Thanks !
