Midi Controll HEX problem
This forum is unmoderated!
Dolkis
Post by Dolkis »
Midi controller: Livid ohm RGB
PF: Latest
We have a problem with the pitchbend midi learn.
Its work in the program "MIDItools_11_win" that test the midi on the computer.
All the other things works that we want to use =)
what can be the problem?
Re: Midi Controll HEX problem
Please show me, your related mapping entry and what the output is when you click on the 'Monitor' button and then use the pitchbend.
What function do you want to effectively trigger within ProppFrexx?
So a bit more details are needed...
Dolkis
Post by Dolkis »
Sorry for my porly English and I didnt thought about the monitor.
When Im opening the Montior window, its not showing me anything at all.
My former midicontroller "Zoom R16" worked so I dont know if its the midi learn in PF or the controller it self that dont rekord it.
Tho there is a mapping for Traktor DJ for the controller and the pitchbend for all the sliders is working there.
Im helping the studio thrue TeamViewer and skype trying to fix the setup but I could not get the problem.
OK, there are a couple of things you might try to see, if that changes things: always use the 'Monitor' window to check, if you receive messages after changing a setting:
a) toggle the 'AutoPair Midi Message' option and see if that changes things
b) check, if the controller offers different operation modes, like a Mackie, a Cubase or even a native mode, try a different mode and check again
c) the OhmRGB seems to have an Midi Editor, please check there which midi message is assigned to the related faders which are not working
Dolkis
Post by Dolkis »
Hi my favorite radioprogram programmer ;D
Well I found the problem.
There is a program for the Livid ohm RGB that I didnt know about yesterday, the guys in the studio installed it and there I found the setting to change the sliders from ctr to pitchbend.
So know its working as it should do and its so awesome!
If you want pictures for your homepage I think we can fix some from our studios!
Just talk to joachim about it!
Many thanks man for your time!
