Log import : choosing start type
TheoOrl45
Post by TheoOrl45 »
Using the import function into the scheduler, all is okay.
But, is there any way to set some settings for the program entries automatically created ? For example, "start type" or "bridge track" ? Something "by default" for all the entries, but something without having to set it manually after import process...
Not very important, but perhaps useful...
Regards,
Sylvain
Theo, from France.
Re: Log import : choosing start type
All default options incl. the StartType might be set within the file called "ProppFrexx ONAIR.importformats", which can be found in your ProppFrexx AppUserData folder.
You might even create new entries in that file if you want, e.g. to create multiple entries for the same format, but with different options being set.
In your case (when using the 'M3U Generic' importer) take a look the formats section for the "<format name="M3U Generic"..." entry...the start type of a new program is defined in the options section.
E.g.
<option name="ProgramStartType"...
<option name="ProgramBridgeTrack"...
TheoOrl45
Post by TheoOrl45 »
GREAT !! Absolutely wonderful !
Theo, from France.
