New mix settings
Re: New mix settings
Yes, the NEXT cue-point of a track defines, when the next track should start.
The other posts above are not clear to me me, ie. I do not understand what you want to say/ask.
djbony
Post by djbony »
I understand. That's normal. It looks like the mixpoint is delayed by one song. He takes it from his previous track, not his own.
djbony
Post by djbony »
any solution?
Example:
Jingles sets Mix-In to Ramp1, Music sets Mix-In to Full-Level. Playlist have SONG-JINGLE-SONG-SONG. After first SONG jingle starts before the MIX point, after JINGLE next song starts late and next song starts before MIX point again. In seque editor is all OK, but onair NOT.
I can not reproduce that here!
I assume all cue-points are set before you load the playlist. I just tested it here and all played as expected. Maybe you set the segues after the playlist was loaded? If yes, note, that the MixIn only works for tracks in advance.
djbony
Post by djbony »
Of course. We've already dealt with it. Right after Mix-In was introduced
djbony
Post by djbony »
Maybe it's related to importing a playlist. The track names were displayed by the imported file, so the mixer tags may be loaded incorrectly.
How do you import a playlist?
But however, as long as the original playlist isn’t a .pfp playlist file or as long as the audio files TAG data doesn’t contain the cue-points they would of. Purse not be loaded. Or did you maybe set the ‘MetaData has Priority’ option?
djbony
Post by djbony »
I'm importing playlist from Powergold. MetaData hasen't priority.
It happens from the time when the song title was displayed by the imported playlist.
Where can I download version 4.0.5.19? Max .38?
The latest version is v4.1.1.0.
I do not maintain the older versions.
djbony
Post by djbony »
I got it. Please solution. Thanks.
