Temperature Announcement
Re: Temperature Announcement
No, ProppFrexx uses: http://openweathermap.org/
And here "Rio de Janeiro, Brazil" works just fine!
vsolivie
Post by vsolivie »
And what is the procedure for me to add this address correctly
Right-Click on the name and a dialog comes up. There you enter it.
If that does not work there seems to do something not ok with your internet connection.
vsolivie
Post by vsolivie »
You refer to this window.
vsolivie
Post by vsolivie »
But I refer to this that appears this other totally different link will it be possible to change this link? Because I've been searching but I have not figured out how to
vsolivie
Post by vsolivie »
v.3.0.12.4
So we can buy the newest version because it suits our needs very well that's why we decided to share it here in Brazil because there is a very large hegemony of professional software that is very good but not as good as ProppFrexxONAIR so if not Has to solve for the fact of being old we wait until we can get the newest obigado for your help and patience for me, Yes we will continue with it for a little more time but soon we are getting the newest we have been looking at the new version and it seems that there are many improvements congratulations by the software hug my friend
What exact ProppFrexx version are you using?!
Are you probably using an old verison?
In the past I was using that service, but they stopped the free and open service, so I needed to change to another service.
No answer anymore?
I also send you a mail...
vsolivie
Post by vsolivie »
Ok then it is explained because the humidity and temperature does not work the information comes from another site this one does not work anymore.
Yes, and you can maybe explain, why you are using an old v3 without a license?!
