ProppFrexx has stopped opening.
Re: ProppFrexx has stopped opening.
Else, just send me these dump eg. via WeTransfer.
Else I still do not understand the condition when it crashes resp. when it doesn’t crash.
Also note, that you are using the Demo v4 version, which terminates automatically after 2 consecutive hours!!!
And have you looked to the SHOUTcast server log? Can you provide that for the time when the error occurred?
WickedSpins23
okay as I cannot work out how to upload the zipped file to the ftp link used WinDbg Preview and used Analyze, I out of my realm here so no idea if the info is of use should I copy and paste the results here?
WickedSpins23
Just seen your reply after I commented above. Will upload to WeTransfer
WickedSpins23
WeTransfer link
https://wetransfer.com/downloads/c37e26 ... 353/55d951
From my Shoutcast Server Log I get this,
2020-10-24 03:34:07 DEBUG [MICROSERVER] Connection received from 185.62.102.68:38891
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Thread 1 amt=6
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Adding microConnection to thread 1
2020-10-24 03:34:07 DEBUG [DST 185.62.102.68:38891] HTTP Request [GET]
2020-10-24 03:34:07 DEBUG [DST 185.62.102.68:38891] HTTP Url [stream]
2020-10-24 03:34:07 DEBUG [DST 185.62.102.68:38891] HTTP Protocol [HTTP]
2020-10-24 03:34:07 DEBUG [DST 185.62.102.68:38891] HTTP Version [1.0]
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Thread 1 amt=7
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Adding protocol_HTTPStyle to thread 1
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Removing microConnection [done: 1, exception: 0]
2020-10-24 03:34:07 DEBUG [THREADRUNNER] Removing microConnection from thread 1
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] HTTP Header [connection:close]
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] HTTP Header [host:37.75.236.142:8082]
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] HTTP Header [icy-metadata:0]
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] HTTP Header [user-agent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Zamsha/1.0 RadioTools/1.0 (https://radio.tools, [email protected])]
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] Checking access rights - addr: 185.62.102.68, inBan: 0, inRip: 0, isCDN: 0, ripOnly: 0
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891] Starting client via auth.
2020-10-24 03:34:08 DEBUG [STREAMDATA sid=1] Stream still has 2 references
2020-10-24 03:34:08 DEBUG [THREADRUNNER] Thread 1 amt=7
2020-10-24 03:34:08 DEBUG [THREADRUNNER] Adding protocol_HTTPClient to thread 1
2020-10-24 03:34:08 DEBUG [THREADRUNNER] Removing protocol_HTTPStyle [done: 1, exception: 0]
2020-10-24 03:34:08 DEBUG [THREADRUNNER] Removing protocol_HTTPStyle from thread 1
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891 sid=1] state_AttachToStream
2020-10-24 03:34:08 DEBUG [STATS] System wide listener total now 2
2020-10-24 03:34:08 DEBUG [DST 185.62.102.68:38891 sid=1] Sending [
HTTP/1.0 200 OK
icy-notice1:<BR>This stream requires <a href="http://www.winamp.com">Winamp</a><BR>
icy-notice2:Shoutcast DNAS/posix(linux x64) v2.6.0.753<BR>
Accept-Ranges:none
Access-Control-Allow-Origin:*
Cache-Control:no-cache,no-store,must-revalidate,max-age=0
Connection:close
icy-name:Wicked Spins Radio
icy-genre:Various
icy-br:80
icy-sr:22050
icy-url:http://www.wickedspinsradio.org
icy-pub:1
content-type:audio/mpeg
X-Clacks-Overhead:GNU Terry Pratchett
HTTP/1.0 200 OK
Accept-Ranges:none
Connection:close
icy-genre:Various
icy-br:80
icy-sr:22050
icy-pub:1
In that log you can only see clients (DST) connecting.
But no source (SRC) connecting (as in my example). So it still seems, that ProppFrexx is not connecting to your server, ie. it might still somehow be blocked within your local network.
However, I'll forward the dump file to have it analyzed by the audio lib vendor!
WickedSpins23
Right I'm looking in my Firewall setting under Monitoring and Action is set to Allow, there are two listings for PF though as you ca see with the attached image grab. Shouldn't there just be one and would that cause any conflict
- Screenshot 2020-10-24 165352.png (10.19 KiB) Viewed 13444 times
One entry is for TCP and the other for the UDP protocol - so that is normal.
However, both are only for inbound traffic, but there should also be 2 for outbound traffic as well?!
WickedSpins23
hmm, it was listed as an Outbound rule but I see it's disappeared so I've just added a new rule but still it's not showing up under the firewall Monitoring section. Also under Inbound Rules there are 6 rules listed
I am not an/your IT admin - the screenshots even look quite different to me.
Lets wait when the audio lib developer find out.
However, as it works for hundreds of other users, I am still very sure, that this is some local issue to your environment/setup/machine.
If you maybe have a 2nd machine somewhere, you might try there with a fresh setup?
WickedSpins23
I understand that this is probably some local issue and if you recall it V3 was working fine until out of the blue this problem started and yet doing a clean uninstall of V3 and installing V4 the problem has transferred over. So somewhere there is a conflict between PF and Windows 10 occurring, so I'm trying to troubleshoot every possibility. I fully appreciate all the help and advise you've given and really would like to be able to solve this so I can purchase the full version. So I am hoping the developer comes back with some resolution.
