Same artist back to back - History check
Re: Same artist back to back - History check
The log file (if you use the standard way) is written with the global even 'Playlist.OnTrackPlay' even, see the general settigns.
So I assume, the track was may be played 4 times that day!
I noticed (during looking at your system via TeamViewer), that you have quite some tight filter rules, which sometimes only results in a couple of possible result entries - together with the gloabl AND script history - this might pretty much limit the choices.
So I don't see, why this is essentially wrong?!
Might be, that your filters are just too tight? E.g. 'Random' out of 100 might result in repeats...?
The script at that time has no "Random" rule.
It has "LeastRecentlyPlayed". That's why I am worried.
Bernd I am sure something is wrong.
Look at the screenshot.
A song plays at 16/04/2016 19:28.
Later I try to find this song in Find Track Window. It shows that this song played last 05/04/2016 17:15
Screenshot 2016-04-16 19.52.14.png (20.5 KiB) Viewed 8151 times
Unless I am wrong, it should display 16/04/2016 19:28
I'll take a look, may be that got broken too?
Please try the new v4.0.1.25.
It fixes a bug with multiple Entry Statistics - which is the case when using the entry stats also on the MLS, as in your case.
In the previous versions I did not consider the most up-to-date stats entry - as normally they should be in sync, but the previous meta data bug, they are not.
Check for Updates
Download error. Please try again later.
Error:
The remote server returned an error: (404) Not Found.
When I click ctrl-C to copy error:
16/04/2016 23:59:18 [v4.0.1.24]:********** Error/Exception Information **********
Error Message: Requested Clipboard operation did not succeed.
Error Type: System.Runtime.InteropServices.ExternalException
Error Source: System.Windows.Forms.Void ThrowIfFailed(Int32)
   at System.Windows.Forms.Clipboard.ThrowIfFailed(Int32 hr)
   at System.Windows.Forms.Clipboard.SetDataObject(Object data, Boolean copy, Int32 retryTimes, Int32 retryDelay)
   at DevExpress.XtraEditors.XtraMessageBoxForm.CopyContent()
   at DevExpress.XtraEditors.XtraBaseForm.ProcessCmdKey(Message& msg, Keys keyData)
   at System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData)
   at System.Windows.Forms.Control.PreProcessMessage(Message& msg)
   at System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg)
   at System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg)
********** End **********
Maybe an internet cache thing - just try again in a few minutes...
