Album cover on website
Re: Album cover on website
Currently you cannot write the actual track's album image to a separate (external) image file by a simple bot command (I might add a related command in a next version).
The macros given above in this post deliver the image as a base64 string representation.
So theoretically you can pass this via EXEC_SHELL_COMMAND to an external application which then takes this and converts and writes it to an image file.
moogwill
Post by moogwill »
radio42 wrote: 06 Feb 2018 12:54 Currently you cannot write the actual track's album image to a separate (external) image file by a simple bot command (I might add a related command in a next version).
This related command you're talking about would be a great update.
we have exactely the same situation here for our DAB slideshow.
https://www.worlddab.org/public_documen ... deshow.pdf
moogwill
Post by moogwill »
will try that ASAP.
Thanks,
T.
gerritk
Post by gerritk »
Works great. Thx!
