Program Control Commands and line input script Challange.
Re: Program Control Commands and line input script Challange.
Reminders do not exits in the Overlay Scheduler. Reminders do only exist in the Program Scheduler - maybe you have one defined there? (I can not check, as you did not send me your Program .calendar file)?
But I don' get your text?! What do you mean by "00:00:16 remoinder says 00:00:16 before start it is in our radio control site"
Sorry, the line i put in is from a website we created, called radio control, we can see add and change the programscheduler and view if PF is in sync with our programscheduler, we can also see in overlay
But i added the requested file in this replay, maby you can make head or tail to this.
- ProppFrexx ONAIR.zip
- Program calendar file
- (3.81 KiB) Downloaded 74 times
- Overlay.zip
- Overlay Calendar file
- (799 Bytes) Downloaded 44 times
I found it, it was the programm scheduler, when you use a script including programscheduler and line input. you have to use the whole 3 hours.
If you cut it in pieces like every hour an new playlist, then the input close at 20 second before the hour.
when i do a 3 hour script and also 3 hours in the programm scheduler, there is no need for a new playlist and boom it works.
That makes sense and is the way it currently works.
Glad you found the issue!
