Multi Track Segue Editor no longer saves.
atlantic
Re: Multi Track Segue Editor no longer saves.
Post by atlantic »
Bernd, I have tried and looked at everything here. Some programs are ok and some are not. I don't know what's going wrong, a few weeks ago everything was still ok. And nothing has changed in the studio here either.
And have you reinstalled the full version of the v4.4.4.1?
As here also nothing has change I that respect since the v4.4.3.3.. I am as puzzled as you and also don’t know where to look at, esp. as I can not reproduce.
Not sure, what I can do to resolve your issue.
atlantic
Post by atlantic »
I'll try deleting everything, including the appdata folder.
atlantic
Post by atlantic »
Indeed, after deleting everything, the playlist works perfectly.
Uff, great it is resolved. If we ever figure out what it was… I am afraid no … :-)
atlantic
Post by atlantic »
Hi Bernd
After reinstalling everything. Everything was working fine again for a week. We have the same error again.
I have sent you the files from the appdate folder.
I already send you various replies.
I tested your entire app data config and I figured, that the standard user (which you told me I should use) has no user right for the Segue Editor. Maybe that’s your issue?
And when I tried the Admin user, all was working as expected. And I could not reproduce your issue.
So as said, maybe your issue is the UAC and the user rights you configured?!
atlantic
Post by atlantic »
That's right, it has been set up that way for more than 6 years and I have never had a problem like this before. Or is it that someone who makes remote-vt's and uses the Segue Editor that these settings only apply if they are also set that way in the playback device.
No. A playlist file is a playlist file, no matter how it is created. But of course you need write access to it.
But what is the exact use case you can reproduce? As I tried all scenarios (incl. all your settings you send me).
If you can reproduce it with a certain playlist and files, please send those over and tell me the exact steps to reproduce.
You also said, it only happens on two of your PCs but not on others?
atlantic
Post by atlantic »
Precisely on the PC in the studio. The hours where people were in trouble (music bed) were recorded with remote TV and I forwarded an hour of that. I've been thinking now that maybe his files (music bed) are set to read only. But the problem is not unique to him. You can't even press Apply Chagens if you've changed something in Segue Editor. Everything worked well for a week after a clean install.
