issue while VT
Re: issue while VT
I just found an old topic with someone experiencing the exact same issue...
viewtopic.php?f=7&t=1638&p=7887&hilit=v ... ndow#p7887
Re: issue while VT
So please clarify what the exact issue is?
Is it a crash, a freeze?
Note, that each ‘Save’ of a playlist by default creates a .bak; except you disabled it actively.
Re: issue while VT
just click the video link posted this morning or look at the picture at the top of the thread thatt is the exact issue.
when clicking to record a voice track the window starts opening and freeze staying incomplete.. when streaming, the on air track keeps Playing till the end, and then nothing happens the screen stay freezed and we have to force PFOA to close.
Re: issue while VT
heres the last error log of the rvt computer
- Error.7z
- (334.25 KiB) Downloaded 496 times
Re: issue while VT
Should be fixed in v4.1.5.3.
- Radiofreak
- Contact:
Re: issue while VT
Hi, i have the same problem with ase you say Stereotool. What do you use for processing Bernd?
Re: issue while VT
I do use VSTs from ToneBlaster.
But ST should also work fine, it just uses more CPU.
