Temperature Announcement
Re: Temperature Announcement
The script.txt actually looks like a renamed .pfp playlist file.
The _synced_.pfp Playlist file comes form a Folder based media lib - which you seem to not even use, as you specified a 'LoadTrack' script-lie mode.
I asked for the .pfs script file ! not a plalyist file!
I want to look at your SCRIPT.
Please excuse me I did not pay attention to this detail
- weather.rar
- (800 Bytes) Downloaded 504 times
I am sorry to say, but it seems, that you did not pay attention to all details I already described:
1) your script still contained an 'Archive' option! I already told you to remove this.
An archive adds an additional history to the script and you even specified the folder based _synced_.pfp playlist containing ALL our weather tracks. I am not sure why you initially even came to the idea, that this is needed.
Press the '?' icon at the very top right to get help about each option.
2) I told you how the macro should be named and that it does NOT start with a captial W, but all small letters.
Your script-line however still contained the macro ${Weathercurrenttemperature} - but it must be ${weathercurrenttemperature}!
After these 2 changes it runs fine here!
The modified/corrected script is attached.
Hello my friend, good night first of all I would like to thank you for your generosity and attention to me, but it still does not work, it's worth remembering that all other functions are working perfectly even at the right time for this ${weathercurrenttemperature}.mp3 not working already, All procedure closely following your information but without success for now I will review again the settings ok
Then again:
What is your result when using the script in a playlist like described above?
What FileNames are resolved?
The only thing that appears is the intro vignette
And you have used my script and double checked, that
a) the Archive field is empty
and
b) the macro name is now correct
and
We can do a TeamViewer session if you need, but that will effectively cost money, see here:
http://www.proppfrexx.radio42.com/purchase.html#support
Thank you but we do not have this amount for these purposes, not that it is expensive but at this moment we are saving everything war economy even our efforts are primarily for our own use but we also publish our findings here https://www.facebook.com/altomatizador And here https://www.youtube.com/channel/UCtoy3O ... v2bGIdmNjw
But as soon as there is a possibility if it is not already discovered, we will contact you for the time being, we will continue to research nothing is impossible
I CAN NOT SAY BUT I THINK YOU HAVE TO SEE MY FIREWALL I'M SEARCHING
