Again error in overlay!!
AladnaFm
Re: Again error in overlay!!
Post by AladnaFm »
maybe a stupid question, but where can I find the Follow setting?
In the Main ribbon tab, just next to the AutoPlay button...
It should be disabled=OFF to guarantee the exact playback order (and it will be disabled also for any automatically scheduled playlists).
Also note, that you should use 3 DJ Player (which are also set by default).
AladnaFm
Post by AladnaFm »
Problem solved! The follow setting was turned on.
I disabled it and everything work fine now!
Thanks again!
