PFOA stoppt nach 30 Min.
Re: PFOA stoppt nach 30 Min.
As said there is NO 30 minute streaming limit within ProppFrexx!
Also does ProppFrexx NOT use PAL, which is only used by SAM !
It was you saying, that a PAL script was the reason for the 30 minute limit not me?!
Im Forum hab ich gelesen, das ein PAL Script was mit einer 30-min-Sache zu tun hat
Where do you found that info? However, as PF is not using PAL I guess you must misunderstood something.
Again, the Basic-Version has no such limit. Your assumptions are incorrect.
Did you try the several suggestions I posted above?
If yes, I guess the reason for the stream disconnecting and not being able to reconnect might eg. be that another source kicks it and then connects instead of PF.
Are you running your SAM in parallel?
