Re-open playlists created by playlist template wizard
Re: Re-open playlists created by playlist template wizard
I guess I saw the issue in your case.
Please try the new v3.0.11.42!
andrerotgans
Post by andrerotgans »
Working ok in .42, nice fix.
Thanks !
André
bebo_saed
Post by bebo_saed »
Hi Bernd, when reopening a playlist scheduled by the playlist template wizard, at the schedule column it doesn't give to me the scheduled time its going to play as scheduled in the program which is for example 6 PM, instead of that it shows me the current playlist schedule time, if it's now for real 4 PM then the first song will be scheduled 4 PM not 6 PM as it's created for in the template wizard, that would cause a problem for the announcer to tell time right in his show, is there an option which in the settings that i forgot to check it out, or its something else
bebo_saed
Post by bebo_saed »
I'm using the latest version 3.0.11.47
bebo_saed
Post by bebo_saed »
This Issue Comes after saving the playlist and reopening it from the program scheduler.
bebo_saed
Post by bebo_saed »
Fixed It, Adjusted Back timing, Sorry for bothering you Bernd :)
