Album cover on website
rockdj
Re: Album cover on website
Post by rockdj »
I will try to explain what I'm looking for..
The 'test.html' works fine! But there only the songartist en songtitle information in it. And I like to get the albumcover info also in that html.
I already understand that there are macros for this. But I don't excactly know where to "place" these macros...
rockfiles.nl 110% rock radio!!
the no.1 rock & metal station!!
rockdj
Post by rockdj »
Ok!! So I just need to fill in the line in "test html", that is located on a map on my computer and automaticly uploads to my server?
atlantic
Post by atlantic »
You should save it as template.php and test.php
rockdj
Post by rockdj »
Is that all :D
So I need to adjust the "test html" and "template html" and fill in this next line in both..
<?php echo "<img src=data:image/jpg;base64,${currentalbumart} width='200' height='200' border='0' title='${currenttrackname}' >"; ?>
atlantic
Post by atlantic »
Create a template.php with this in it.
<HTML>
<script src="/A2EB891D63C8/avg_ls_dom.js" type="text/javascript"></script><script>
Auto Refresh Page with Time script
//enter refresh time in "minutes:seconds" Minutes should range from 0 to inifinity. Seconds should range from 0 to 59
var limit="0:45"
if (document.images){
var parselimit=limit.split(":")
parselimit=parselimit[0]*60+parselimit[1]*1
function beginrefresh(){
if (!document.images)
return
if (parselimit==1)
window.location.reload()
else{
parselimit-=1
curmin=Math.floor(parselimit/60)
cursec=parselimit%60
if (curmin!=0)
curtime=curmin+" minutes and "+cursec+" seconds left until page refresh!"
else
curtime=cursec+"Station naam"
window.status=curtime
setTimeout("beginrefresh()",1000)
window.onload=beginrefresh
</script>
<style type="text/css">
.style1 {
	font-family: Verdana, Arial, Helvetica, sans-serif;
	font-size: 10px;
	color: #FF9900;
	font-weight: bold;
body {
	background-color: #020202;
	background-image: url();
.style3 {color: #FF0000}
.style6 {color: #666666}
.style9 {
	font-size: 10px;
	font-weight: bold;
.style11 {color: #FFFFFF}
.style13 {color: #658BD8}
</style>
<BODY>
<p class="style1"><span class="style13">Current Track:</span> <span class="style11"> <?php
?>${currenttrackname}</span></p>
<p class="style1"><span class="style3">Next:</span> <span class="style11"><?php
echo "<img src=data:image/jpg;base64,${nextalbumart} width='200' height='200' border='0' title='${nexttrackname}' >";
?>${nexttrackname}</span></p>
</BODY>
</HTML>
No, the test.html is created out of the template.html, by replacing all macros....so you only need to adjust the template file!
You can place this line into your template file (as posted by the user):
The resulting test file might not work locally anymore (as it requires PHP to be installed/available) - but it should work fine on your web-site (assuming you have PHP available there).
Yes - I mean the line given is just a sample...you might modify the template a bit more, so that it is aligned to your web layout...but basically yes - that's all.
A good place is the global event called "Streaming.OnSongTitleChanged" - see general settings, section 'Events/Commands'.
gerritk
Post by gerritk »
for our dab transmitting we want to use the album art for the slideshow (some radio's can show this).
We simply want to copy the album art from Proppfrexx to a given map (so the dab mux can handle this).
What command can we use?
EXEC_SHELL_COMMAND or
EXEC_WRITE_FILE
Thanks.
Gerrit
