Gender and Country MetaData Default Values
Re: Gender and Country MetaData Default Values
Are you using the 32 or 64 bit version? are you sure ProppFrexx shows v4.5.0.6 at startup?
Note, that it was added to ProppFrexx ONAIR ! and not the Tagger app yet!
I guess you are talking about the Tagger? There it still needs to be added...
atlantic
Post by atlantic »
I am using 64-bit, and upon startup, the version shows as 4.5.0.6. I have already performed the update on 3 PCs, and it’s the same each time.
Indeed, I am talking about the Tagger that is included by default in the package.
ndeed, I can find it in ProppFrexx Onair itself. And indeed, it is not yet present in the tagger itself. My misunderstanding.
This is now also added to the new v4.5.0.7 (which basically adds it to the Tagger app as well).
atlantic
Post by atlantic »
Thank you for the update.
