v4.5.0.0-.7 - stable
Re: v4.5.0.0-.2 - stable
What do you need to know about the UI or audio lib. These are the latest versions from the resp. vendors. Mostly security and stability, compatibility updates.
No significant or relevant new feature, which are specifically worth to mention.
claudius06
Post by claudius06 »
OK fine, no more requests. Thank you!
audiostreamen
Re: v4.5.0.0-.3 - stable
Post by audiostreamen »
Dear Bernd,
Could you provide some clarification on the functionality of the following new feature: MusicMaster Nexus support (initial, Audio Sync)?
Your insights would be greatly appreciated.
Regards,
Benny
it is first the Track synchronization which was added.
To configure it, you first need to define your MusicMaster settings. Go to the general settings, section Folder/Libraries and click on the 'Scheduler Automation...' button.
In 'Scheduler Automation' dialog enable the 'Use Music Master Nexus' checkbox and click on the ' Music Master Nexus...' button.
Here you need to specify your MusicMaster settings…
Beside the address etc. the most important field is the MusicMaster CutID – which is the unique ID in MusicMaster. By default 101 is used.
Plus you need to define the Field Mapping. I.e. remove all fields you don’t need or have in Music Master – plus you MUST specify their related MusicMaster field IDs!
If you have questions about the field IDs etc. you can consult you MusicMaster support – here it is actually the mapping which ProppFrexx meta data field should be mapped to which MusicMaster field id.
It is an xml config file – so don’t mess the xml format 😉
(ignore the Pubish buttons for now – they have no function yet!)
Once this is defined, you can go to your ProppFrexx Media Libraries… and sync them with MusicMaster.
When you now right-click on a media library and select ‘Export…’ you can now choose ‘MusicMaster Nexus’ and click on the Export button.
The MediaLibrary will now export/synchronize with MusicMaster Nexus (create or update songs in Nexus).
The speed is (in my mind) disappointing – even if MusicMaster told me, that the speed is very good and as expected.
So please do not blame me – this is limited by the MusicMaster API resp. Nexus database speed!
Please test this, if this is working fine for you.
MusicMaster told me, that most users still publish and import the schedule via the normal log files (as you do now).
Peter Maerlandt
Post by Peter Maerlandt »
Bernd,
Thank you for the renewed Tageditor. Long awaited, but finaly we can save and go to 'next'. Great job. I'm excited.
Re: v4.5.0.0-.4 - stable
A new v4.5.0.4 is available which adds a meta data compatibility option for RadioBOSS as well it adds the new Gender and Country also to the find and filter dialogs.
Re: v4.5.0.0-.6 - stable
The v4.5.0.6 fixes an AutoSweeper issue and even adds 2 new transitions for it.
Plus Default Values for Gender and Country have been added.
Re: v4.5.0.0-.7 - stable
The new v4.5.0.7 now also adds the default values (for Gender and Country) to the Tagger app.
