Qcon pro
robbedoeske
Re: Qcon pro
Post by robbedoeske »
Its a foto hope its clear enough:)
Re: Qcon pro
Ahh, you need to put a pipe symbol (|) between the parameters. Ie.
DJ A|${….
For the general syntax:
<> brackets denote a parameter.
[] brackets enclose an optional parameter.
The brackets itself are never written/used.
Multiple parameters are separated by a pipe symbol (|).
There is only a single space between the command and the subsequent parameter(s). Else, no extra space should be used before or after.
robbedoeske
Re: Qcon pro
Thanks that did it!
