Scripting restriction
Re: Scripting restriction
I really investigated all code, but I cannot reproduce the error - so how can I fix it.
I even rebuild your script, media lib etc. Here it works as designed - I even compared the versions in source code, but could not find any root cause for the behavior... so I guess we need to dig deeper, but currently I am a bit puzzeld.
Please send me your entire scheduler calendar, your script file (.pfs) in question to exactly use your setup...
Thanks for sending the data...
In your Proma lib are 12 tracks, but for 10 tracks you set a restriction so that they are NOT played from January to December (all months). I.e. effectively, here are only 2 tracks in your lib.
As you set the Global History to 50 entries and did not set the SuppressHistoryCheck script-line option for the Proma entry, this means, once the Proma tracks are in the global history, they can not be played anymore due to the history check - this regardless of any other restriction you have set.
So as a esolution, please set the SuppressHistoryCheck script-line option for the Proma entry.
After adding this option all is working fine here. I also added a restriction to the two remaining tracks (one to not play on a Saturday and one for Sunday) - all was working as expected (i.e. today, Sunday, one of the tracks have been excluded)!
djbony
Post by djbony »
Thank you very much for your help....
