How can I update the markup of all updated tracks in the current playlist?
relax
Re: How can I update the markup of all updated tracks in the current playlist?
Post by relax »
4) I selected all files (CTRL+A)
5) Re-Read the TAG data (CTRL+ALT+T)
6) Time in files hasn't changed
Does it work with all track types or just songs? I set track type "weather".
It should work with any type.
Have you many be set any specific options on this type or track?
Maybe you can try with a plain new track not having any option… else check your media type related options.
relax
Post by relax »
No, all file are wav format 44100, stereo, 1411kbpts without any specific options.
[i]Maybe you can try with a plain new track not having any option… else check your media type related options.[/i]
I tried with a simple song, same problem.
I mean in the track options (ALT+3) as well as the general settings…
As you can see, in my example it works. Maybe you have excluded the TAG saving?
Please close your pls (without saving it) and reopen it. Are the cue-points saved when you now re-read the TAGs?
Please show me these settings...:
