MODStream in statistic report
Re: MODStream in statistic report
another screen shot from the multicast server
- Screenshot_20210203_134622.png (7.4 KiB) Viewed 9309 times
By the way. The SongTitle in the MODStream player is visible while the live show.
I guess there is a missunderstanding here.
A MODStream Watcher listens to the given URL (i.e. as a client).
Thus ProppFrexx is NOT feeding the signal TO that ICEcast server, but instead it receives the signal FROM that Icecast server.
I.e. there is someone else streaming to that ICEcast server as a source - this source is now responsible for SongTitle changes.
The meta data (song title changes) is then being received by ProppFrexx (the MODStream) from that ICEcast stream.
Thus just because there is some static text on the ICEcast doesn't necessarily mean, that this info is given to ProppFrexx in the stream.
If the MODStream URL itself doesn't provide SongTitelChanges, you must at least provide an initial song title with the command starting the MODStream Watcher...
'If the MODStream URL itself doesn't provide SongTitelChanges, you must at least provide an initial song title with the command starting the MODStream Watcher..."
Now I understand.
Thanks. I'll type in the initial SongTitle. We'll see if that resolve the problem.
Thanks again for you time.
Now I understand.
I’ll also double check the code here to see, if I didn’t make any mistake here myself!
Bad news. I type in TitleSong like on the attachment. After the live show that was between 7:00 - 9:00 I opened the stat file. Still don't see any information about the modstream feed.
I'll a look into my code again - it might be the case, that in MODStream SongTitle updates are currently not considered for entry- and log-statistics at all, as those tracks come from an external source and are not being played directly by ProppFrexx - I need to double-check this.
This for example is also the case for LineIn Feeds as well.
Do you mind explaining, why you need log statistics for played tracks coming from a MODStream URL?
Or is it just so that you know, that the MODStream itself was started?
Thanks for the replay.
I need the MODStream to be noted in the statistic because of the license authority.
The remote DJ's play music in theirs show. I have to know how many listeners been listened to the show and then send the report to the licensee authority.
But for this you might also use the standard logging and e.g. place the command used with the 'Playlist.OnTrackPlay' event and move it to the ''Streaming.OnSongTitleChanged' event.
You can then freely configure your log file in the general settings, Histiory/Logging section.
Alternatively use the EXEC_WRITE_GLOBAL_LOG instead.
In the log file configuration (general settings, Histiory/Logging section) you might then even use the ${streamingtotallisteners} macro to record the current listener count from your configured steaming servers.
