Marked and remove played
Farbo
Re: Marked and remove played
Post by Farbo »
So I don´t understand. I will have to make some more tests.
Peter
Farbo
Post by Farbo »
I know when this occures. When opening just media library it is not working, try to open some media library and start Autoplay, you will see remove played is not working, even when manually turned on. But when creating normal manual playlist it is working so everything should be fine.
Peter
Ahh, now I understand.
This is actually (of course) by design!
Otherwise playing a media lib might delete all its tracks once saved afterwards ;-)
Farbo
Post by Farbo »
I see, logical. :-) So problem solved. Thank you.
Peter
