Media libraries and playlists gone in media library server
Re: Media libraries and playlists gone in media library server
When you try to edit the media libs file yourself you need to do it correctly.
I'll take a look at your edits tomorrow, but your manual modifications are obviously not fully correct.
friso
Post by friso »
Bernd
This morning i saw that my /CD folder still says 0 files.
So i had asumed maybe it has something to do with the sync files in the folders.
I removed them all and after that it looks OK now
Hopefully it stays this way.
Thanx for the advise
Friso
Assuming you edited your .medialibs file correctly; the ONLY reason, when a media lib doesn't show up is because it cannot be loaded.
E.g. the path does not exist; or a _synced_.pfp file is corrupt.
So validate these 2 option and in case the _synced_.pfp is corrupt (e.g. try loading it manually from PFOA) - delete it.
