Having trouble recording
DjAngel
Re: Having trouble recording
Post by DjAngel »
I dunno how.. but I desperately need someone to help me please.. whether on teamviewer or something.. I'm panicking and have 1 day to figure this out.
I've also tried researching downloading a program to run separately to record live streams from my computer, but all I can find are ones to record streams coming TO my computer, and really confusing programs to record streams coming from my computer but they won't set up right! :? :?
I'm pulling my hair out! :cry: :? :shock:
DJ_Angel
Post by DJ_Angel »
.... I dunno.. the program was set up for me, so I didn't do any part of it... but I'm scrambling here since I only have 1 day left before needing to record the broadcast, and I'm desperate for help.. (I can do teamviewer if need be) :shock:
I've also tried researching for an outside program to record a live stream off my computer into a .mp3 file, but the only results I've found is either to record a live stream coming TO my computer from an outside source like another station; or a program that conflicts with recording my mic and music from Proppfrexx at the same time (it produces a loud squeal). I've also tried Audicity but it doesn't work.
Please help! :oops: :? :?
DjAngel
Post by DjAngel »
I've replied to this comment twice already but it keeps being deleted. dunno why..
But I don't know.. the program was set up by someone else for me. And I don't know what I have to do to record both the music and mic together.. I'm coming down to the wire right now since the show broadcasts TOMORROW.. :? :?
I have teamviewer and I'm desperate for help... I'm scrambling trying to find any options I can right now.. I've even tried researching for any outside program to record the show while I am running it but the only results I've come up with either record from another radio station coming TO my computer... or really confusing programs that will counteract with the Proppfrexx and won't record properly.. ending up with a squeel in my mic...
PLEASE HELP ME! I'm at the point of pulling my hair out.
a) make sure when you right-click on your REC button, that the "Auto Sensing" is set to 'Off'.
In your general settings, section 'Encoding/Recording', make sure you have selected an appropriate filename pattern under the property 'Manual Mixer Channel Recording' - for 'Recording Filename'.
Set this Recording Filename to: Rec${mixer}_${id}
(yours is currently using an incorrect macro pattern)
Then just try it again...
DjAngel
Post by DjAngel »
ok I just set it to what you instructed and it FINALLY worked... problem is now, that the mic sounds like it's being echoed... do I need separate headphones?
Good.
The echo is probably because you are forwarding the MIC channel to that other output channel you are now recording.
You might simply MUTE that output channel (press the 'M' button).
However, what version are you using, as it seems from your screenshots, that you are using an unregistered demo version?!
