GPIO Client
Re: GPIO Client
I just tested it here again; but unfortunately I can not reproduce your issue here.
The GPIO Client application starts with ProppFrexx ONAIR and also shutdown when I close ProppFrexx ONAIR.
It also restores all settings, just as expected...
Re: GPIO Client
Thanks for the info. I investigated this and I guess I found something. I'll provide a fix soon.
friso
Re: GPIO Client
Post by friso »
Bernd
Thanx for the quick input. I will try it this evening when i get home.
Friso
friso
Re: GPIO Client
Post by friso »
Bernd
I have tested it in some scenarios, and most of the issues are solved.
One small thing might be fixed in a next release.
The settings now are stored correctly, and after restarting proppfrexx settings are OK. One small bug though.
When you change someting in the settings, lets say drop a slider from on to of or off to on, after closing proppfrexx the GPIO client stays running. Manually closing it works ok.
When opening proppfrexx and GPIO client is started opening the gui clicking some tabs and NOT changing anything does also close the client when closing proppfrexx.
It looks like changes are not autostored or some element can't close at a right way when something changed in the settings. That could be the reasen that some process is keeping proppfrexx from closing it.
As i said, not a big issue, but when you have time please look if you can find a solution to this.
Anyway Thanx for the quick fix
Friso
Re: GPIO Client
Here this is not happening! It always closes on my 3 test PCs.
So it might be something specific on your system?
Re: GPIO Client
Please try the new v4.0.0.18.
The GPIO client was optimized in various ways.
Also the GamePort support was completely reworked (which caused the error you posted).
