Script line rules
Re: Script line rules
As a TV session was not possible.
Check the Genre in your media lib being used.
If it is a folder based lib, try a Rescan to see if that helps. If it's a playlist based lib, open it in a playlist window and re-read the TAG data for the entries in question.
Within the script editor try the Test button in the Filter Expression builder....
I am sure you'll find a reason by trying one of the above.
