PF has stopped working
Re: PF has stopped working
Do you happen to have the full windows event log resp. even a dump file available?
So that I can send that info to the BASS developer to check...
No I did not create a dump file because I was in hurry to go to studio and start my program again.
The windows event log is what I 've sent you.
There is also a Report.wer file which I sending you by PM
OK - thank you - but really strange, that it never happened with any other user?!
We need to investigate...
v3.0.4.23 should contain a fix!
