Hello.
djanji
Hello.
Post by djanji »
I was wondering how you can export to xls all played tracks, which would require the agency to copyright which I have to attach each month.
Thanks for your reply,
Jani
Re: Hello.
By default all played tracks are logged to a comma-separated file per playlist (program).
The files are by default written to the ProppFrexx AppUserData folder in a 'log' sub-folder.
The files can directly be imported into MS Excel and further be processed.
All log format settings can be adjusted in the general settings, section 'Logging' - see Playlist Logging, 'Log File Entry'.
The entries itself are written by the 'Playlist.OnTrackPlay' event, see general settings, section 'Events/Commands'; 'Playlist.OnTrackPlay': EXEC_WRITE_PLAYLIST_LOG ${yyyy}${MM}${dd}_${plsname}
