Cartwall Empty + Crash
Michiel Bouwmeester
Post by Michiel Bouwmeester »
Unfortunally after the update the carTwall is empty.... so somewhere the "update" doesnot work. The library is gone.
Also PF crashed. The log file has been e-mailed.
System win 7 - 64, amd 3.2 & nvidia video.
Michiel
Re: Cartwall Empty + Crash
I'll take a look at it !
It doesn't seem to be related to the carTwall change!
According to your error.log, the error happened within the 'ControlRoom/MessageCenter' when trying to activate the message center tab (actually a new message is about to be shown there).
The error is a bit odd and looks like a bug inside the UI library I am using.
If the error even happens again after a restart/reboot, please try to close PFOA and delete the following file within the ProppFrexx AppUserData folder:
"ProppFrexx ONAIR.RSSReader.layout" (resp. if you are using UAC, also any " ProppFrexx ONAIR.RSSReader.*.layout")
Michiel Bouwmeester
The update happened after the update. A reboot fixed this problem. However the cartwall was empty after the update, all cartwall lib's are gone.
Ons this machine not to much of a worries but on the production machine this would be a disaster.
In many of the script there are car"d"wall references....
Michiel
Should now be fixed in v3.0.12.6!
Michiel Bouwmeester
Ok thank you, will test during the weekend.
