Resizing Sections Doesn't Stay
RedPanda
Post by RedPanda »
So I've arranged the docked windows in ONAIR in a way I like.
One window I have set for Cardwall 1 to display 1 row of cards horizontal.
Everytime after closing and restarting ONAIR, it loses this setting and defaults to 2 rows of cards horizonatlly.
Why is this? Is it not possible to have it like this?
This photo shows the way I like it set, but when I restart ONAIR, the single row of cards becomes 2.
And this is what it looks like AFTER I re start ONAIR:
Why does it change?
Re: Resizing Sections Doesn't Stay
Yes, that seems to be indeed a bug within the UserInterface library I am using.
It seems to only happen, when 3 Panel-Containers are docked above each other - however, its a bug.
I'll check to see, if I can find a workaround and also file a bug with the company developing the UserInterface library.
RedPanda
Post by RedPanda »
Cool. If you want, you can move this post to the bug report section.
This issue should now be fixed with v3.0.12.4.
RedPanda
Post by RedPanda »
Thanks! I can confirm the bug has been fixed.
