Backup Restore Failed
workino
Post by workino »
After a computer change i reinstalled all but when in proppfrexx i try to restore backup it show my a windows with restore Failed.
Re: Backup Restore Failed
Any more details?
As the window being displayed when the restore failed typically shows a more detailed error reason.
Beside that you might also try to manually copy the config files from the backup directory directly to your new ProppFrexx AppUserData folder.
workino
Post by workino »
Sure
I'm done with manual copy. But I preferred to send you this problem.
Thank you for your great work
