v3.0.11.37 - stable
v3.0.11.37 - stable
Version 3.0.11.37 is out!
What's New?
  • Volume-Point handling optimized
  • Script-Rules bug-fix
  • SupressExclude Filters enhanced
  • Various other optimizations
  • Other smaller bug-fixes
  • stable
So far Volume-Points and Cue-Points (In/Full and Fade/Out) have been tightly coupled.
Adding one of the above cue-points has set a corresponding volume-point.
This is now NOT the case anymore! Cue-Points and Volume-Points are now totally independent.
This means, that the Fade-In (corresponding to the cue-points In/Fade) and Fade-Out (corresponding to the cue-points Fade/Out) are executed and defined independently and in parallel to any other volume-points.
This makes it now much more clear and easy to define additional volume envelopes, e.g. for voice tracking or other volume attenuations.
The WaveForm now also displays the Fade-In/Out in parallel to the regular volume points.
On your side you don't have to care about any migration etc. all is automatically converted internally.
So far the 'EnbeddedContainer' media entry type has been missing in various supress/exclude filters, e.g. the 'Supress SongTitle' update filter.
All missing media entry types have now been added to all supress/exclude filters consistantly.
