Hello there, USB things!
This forum is unmoderated!
Dolkis
Post by Dolkis »
Is there anyone that have or wants to try to connect a USB source to PF?
With pads and all the things so we dont need to use the keyboard or the mouse more then needen? =)
It would be coolt to se your PF setups 2. I run it on 2 screens! :)
Re: Hello there, USB things!
What USB devices are you thinking of?
Are you talking about remote controlling PF?
If yes, there are several ways to do so, but a bit more details are needed to answer your questin.
Dolkis
Post by Dolkis »
yeah, i wondering if there is and USB mixerboard like Pioneers DDJ T1, so I can controll PF thrue that, and play it with decks and souch cool things.
I just wanna know if there is someone that is using this option in PF atm. I have a friend with a Ipad and using that to controll some things in PF with a program :)
Native USB controllers are not directly supported, as there is no standard for them.
However, most controllers are capable of handling (sending and receiving) MIDI commands.
If that is the case, there shouldn't be any problem with it.
