change frequenty played songs
- Soulmaster
- Contact:
How can I prevent a song from being played so frequently? Currently, some tracks are being played as often as every two hours, even though there are thousands of songs in the folder.
Re: change frequenty played songs
A) check your script-line mode and try the ‚LeastRecentlyPlayed‘ mode
B) check your global Song History settings
Also see the History tutorial video: viewtopic.php?p=3942
Plus search this forum, there are many many topics on this subject. But most often it’s solved by either A and B.
Show me your script and media libraries to take a look at -
as else, I can only guess.
