Double songs on playlsit
- Soulmaster
- Contact:
After briefly straying to another playout system, I’ve returned to ProppFrexx because there simply isn't a better one. However, after reinstalling everything, I’ve run into a problem: the playlist is showing two songs for the same time slot instead of one.
Re: Double songs on playlsit
Are the meta data correctly set, ie. In this case the duration of the tracks?
And how is the playlist generated?
Is it an import from an external log file? If yes, which one and is that log maybe already using these wrong times?
- Soulmaster
- Contact:
Fixed the problem.
script for the playlist was wrong
