layout set back
This forum is unmoderated!
Johnny_
layout set back
Post by Johnny_ »
Hi, how can i set back the layout for these?.
Greets
Johnny
Re: layout set back
General settings - Look and Feel… Reset Layout…
Or what exactly do you mean by „…for these“?
Johnny_
Re: layout set back
Post by Johnny_ »
i dont see, i want complete the first situation back.
the cart wal and stream is moved to bottom it wass before a split above the logo and streaming setup etc. now is al in one on the right.
Greets
Johnny
Re: layout set back
Sorry, my mistake - it is in the ‚Look and Feel‘ section.
I corrected my initial answer…
Johnny_
Re: layout set back
Post by Johnny_ »
i just found that. but there is nothing change. when i that option choose.
Re: layout set back
You need to restart PF after!
Else, close PF and delete all *.layout files from the AppDataUser folder of ProppFrexx. And restart spar after.
Also note, that you can use the Workspace ribbon tab menu to create/save and restore multiple layouts…
