overlay
Michel67
overlay
Post by Michel67 »
How can I pause or stop a started overlay?
Re: overlay
You first need to enable the options in the Overlay Editor settings under Options.
Then you can use the UI controls, eg. to cancel the Overlay press the Cancel button in the Overlay Player.
Michel67
Re: overlay
Post by Michel67 »
That worked, thanks. Now I'd like to prevent jingles from starting while an overlay is playing. The reason is that overlays play on my AirLite via channel 7, the same channel as the overlay. After the jingle plays, that channel is automatically muted. I'm using Benjamin's AirLite settings. Is that possible?
Re: overlay
Yes. See here: viewtopic.php?p=19693
Michel67
Re: overlay
Post by Michel67 »
This doesn't quite apply to me. I want to prevent a jingle (via PFOA Cartwall or Airlite) from playing while an overlay is playing. So, simply put, temporarily disable Cartwall completely.
Re: overlay
Ah okay. That is not possible. There is no option to disable the cartwall completely.
The only option is to just not using the cartwall at that time.
